Page 3 of 9 FirstFirst 12345 ... LastLast
Results 21 to 30 of 90
Like Tree14Likes
Thread: JetMouse Garmin Keygen v1.5 with Checksum Fix
  1. #21
    May 2011
    Re: JetMouse Garmin Keygen v1.5 with Checksum Fix
    Wow, i hope it's that simple! I need that City Navigator North America NT 2011.40 card in a couple of months.
    Thanks a lot for your help. Will come back to post results!
  2. #22
    Jun 2011
    Quote Originally Posted by lelici View Post
    Alles naar de SD card gekopiert, maar krijg de melding Kan kaarten niet ontgrendelen.
    Enig idee. MapId:2419 heb ik ingegeven.
    Considering the fact that this is an English speaking forum and not a Dutch speaking one. I think you might have more success when you post your questions in English.
  3. #23
    Jun 2011
    Link is dead, can someone please re-up it?
    Thanks!
  4. #24
    Kor@l's Avatar
    Kor@l is offline Global Moderator
    1,967
    344
    Quote Originally Posted by Reidler View Post
    Thanks!
    All links are online, control again.
  5. #25
    Jun 2011
    tried everything, spent hours and sorry to divert people but this is a simple no fuss solution that worked for me - it's one executable and no pids, fids, keygens, viruses, blah, blah
    Fast IMG Unlocker
  6. #26
    Jul 2011
    Need help with JetMouse
    I've just joined the forum and am struggling with Jetmouse. I have downloaded JetMouse (with Checksum fix) and need some help. If I enter the 62s unit I.D. can I transfer the maps directly onto a Microdisc on an adaptor in the computers USB port or do I need to insert the SD card serial number. I've searched everywhere and cannot locate the Microcards serial number. Secondly, in the box "Select Software product" there are only two choices - Garmin Mobile XT and Garmin Mobile PC. I have a Garmin 62s - which one should I select. Lastly, where is patched file I should be replacing located.
    Snowgoose
  7. #27
    Kor@l's Avatar
    1,967
    344
    Re: Need help with JetMouse
    I think you have not understood what Jetmouse is used for.
    You need jetmouse only to generate an "unlock code" to ad in Mapsource or in UNL file(unlock code file)
    to trasfer maps in SD/MicroSD/Device/HardDisk you must use Mapsource.
    If you dont have a MobileXT/PC you don't need an unloc code for the software, the only thing you need is an unlock code for the Maps, so write your ID UP and work only with the second box "Select Map Product:"
  8. #28
    Jul 2011
    I generated the 25 digit unlock code but the detail on the map remains locked. How do I unlock the map detail?
  9. #29
    Kor@l's Avatar
    1,967
    344
    There are 2 things
    1) you have done something wrong, take a look at the Map ID often people write it wrong, control device ID too,
    2)Your device has GMA protection so you can't unlock only with UNL file, have to use an Unlocker tool. Usualy when device have GMA protection will see " the map is not authenticated"
  10. #30
    Jul 2011
    Hi Kor@l, can this tool unlock the new maps which are not having the img structure? Where can I download this tool?
