Thread: Safety Camera Icon(s) not showing up is this normal ?
    Louise24 is offline Private
    I have unlocked and installed the safety cameras in to Garmin following the instructions provided, and when I near a safety camera I get a message that flags up in the centre of the screen that warns me of this. However, on the map there is no icon to represent it, is this normal? if not can you please advise how I can install cameras with an actual icon?
    Should the safety camera icon(s) be showing in the POI'S? extras?
    P33dro's Avatar
    P33dro is offline General
    Australia n.s.w.
    2,676
    168
    Re: Safety Camera Icon(s) not showing up is this normal ?
    Garmin safety cameras not show if you only browse maps you must create route and simulate, then it show cam icon
    3,134
    216
    Quote Originally Posted by Louise24 View Post
    Have your camera files saved as GPIs file.
    Placed them in POI folder.
    All will work well when navigating.
    Download the file from poiplaza.com
    surfguy17 is offline Private
    Sep 2011
    Whats the difference between downloading them as a speedcam and downloading them as a POI from the site? i also wanted to know how to put the icon that comes in the folder on the map. i couldnt find any instructions on the site to do so
    nosha is offline Staff Sergeant
    Mar 2011
    92
    15
    Louise24,
    In answer to your question, NO this is not normal; I have replaced mine and added extra countries (France for this years holiday), and yes at EVERY fixed speed camera the icon showed on the road as well as the red banner along the top of the screen.
    My Garmin Nuvi also has another POI file in the POI folder as well as the GPI files and matching UNL files for each country... Does yours?? Other than that I'm sorry I can't help further, I would ask Kor@l as he seems brilliant at answering these sort of questions.
