Page 3 of 94 FirstFirst 123451353 ... LastLast
Results 21 to 30 of 937
Thread: Garmin Cyclops™ Safety Cameras - EU, AU, NA, ZA, RU, ME
  1. #21
    re: Garmin Cyclops™ Safety Cameras - EU, AU, NA, ZA, RU, ME
    I'm sorry but I'm a numpty also.
    I have the files copied to the device (765T) but please could you give me a step by step on the key creation?
    Many thanks
  2. #22
    Many many thanks.
    All works perfectly
    And we know how... but its neccesary a little of imagination, time and work
  3. #23
    I think that I'm missing something too, tried just coping them over but get the 'locked' message.
    Is it just a case of changing the Family ID in the .unl file to the model of device I have? in my case a 765T.
    Thanks,
    B
  4. #24
    Alternative database (no keygen or UNL file required) - Garmin UK Speed cameras 07-April-2010
    http://www.demonoid.com/files/details/2269207/23133789/
    CSV files - use Garmin POI Loader to transfer to SatNav.
  5. #25
    Quote Originally Posted by Remmie26 View Post
    where do you get the keygen?
    Try this:
    http://hotfile.com/dl/40190584/a8dcdf8/keygen.rar.html
    or
    http://rapidshare.com/files/306374741/GKGv15_5D.rar
    or
    http://hotfile.com/dl/20716633/ce77da5/GKGv15_5D.rar.html
  6. #26
    Hi, thanks for the upload.
    After copying all files to ~/Garmin/POI my nuvi 255W gives me the message that it cant open them (they are locked).
    Plz help, I need to travel to Greece in few days.
  7. #27
    Many thanks.
    All works perfectly!!
  8. #28
    Sweden
    20
    Should I copy both unl and gpi or only gpi?
  9. #29
    France
    136
    You must create a UNL file using your GPS id and info in the UNL file. Copy the key created from Keygen into UNL file replacing all existing data. Copy both files to POI folder on GPS.
    UNL file and GPI file must have same file name. Beware your UNL file does not have a txt extension hidden by Windows! This will stop it working.
    Good luck
    A
  10. #30
    Could those who have managed to get it working explain to those who can't how to do it.
