Results 1 to 1 of 1
Thread: Garmin Travel Guide NewYork
    ozboss's Avatar
    ozboss is offline Captain
    541
    49
    Requirements: Garmin devices
    Overview: The City Guide is all you need for daily activities on your trip to New York.
    AA reviews, prices, opening times and facility details are a touch away. After reviewing the information, touch “Go!” and your Garmin device will guide you there with detailed turn-by-turn directions.
    More Info:
    www.garmin.com
    Download Instructions:
    Download Netload Garmin TravelGuide NewYork or Download via Relink.us
    * Family ID : 386
    * Product ID : 1
    * Region ID : 13
    * Vendor ID : 1
    How to get it working.
    1- Enter Unit ID into keygen.
    2- Chose Custom mapset, enter 386 for map ID
    3-Check the "Enable additional fields (experts only!)"
    in Product ID ; 1
    in Region ID : 13
    in Vendor ID : 1
    4-Hit generate button
    5-Copy the code and paste in Notepad
    6- Save as AA_NewYorkGuide.unl (make sure no .txt behind it)
    Put this AA_NewYorkGuide.unl into Garmin\POI folder (ie, put together the file AA_NewYorkGuide.gpi)
  2. The Following 10 Users Say Thank You to ozboss For This Useful Post:
