use Mapsource and GMAP anywhere (portable)
You can use Mapsource and gmap folders easy from anywhere
1. just copy mapsource.exe (and maybe your language file mapsourceXXX.dll) to eg. your USB drive [x]:\Mapsource
2. make directory [x]:\Mapsource\Maps
3. copy all GMAP folder to this Maps directory and run [x]:\Mapsource\mapsource.exe
( You can use any directory just make Maps folder to same directory with mapsource.exe )
this way you not need copy all your maps to %APPDATA%
That trick not works with old mapsource versions....eg. 6.16.3 works fine
Usefull eg. with mini laptops with tiny harddisk
MapInstall and basecamp (basecamp need some dll files also) works fine also same way
attached only .exe...Code:USB Mapsource with language files or HERE
This is another neat trick that I found out by mistake.
If you copy your whole Garmin to a USB key fat 32 (not a portable hard drive).
You can fool Basecamp and Mapsource and Mapinstall think that your garmin is connected to the computer.
I have tried this and I can open mapsource via my USB on another computer. But I can not see any maps in mapsource. Can you tell me what I have to copy in the map Maps? I only see img files in my Garmin folder
Thank you
