what is a .unl file
what is a .unl file
Hi
Ive downloaded the unlocked maps and put them on ok, question is where can i download the latest .JCV files for my 1410?
Cheers
XXXX.ASR and XXXX.SRX for voice command in ASR folder
XXXX.DB for TrafficTrends in SQlite Folder
Normally don’t come with the map like the case of “City Navigator Middle East & Northern Africa NT 2013.40”
The questions:
Are they updated automatically when update the nuvi software, or in additional softwares, or there is special thread for them to be updated, like the DEM Maps
Thread: DEM Maps From nüvi 3XXX series
Please advise how to update the additional Garmin Additions Files (ASR, SRX & DB)
Thank you for your time![]()
Hi Folks,
May I ask which .JVC file is needed for the nuvi 40?
I see that they normally come in high res and low res versions.
Thank you.
Ian
When you download a map, usually in the thread are posted JCV files for any device, asking here is pointless, it depends what map you are using, so ask at the map thread if someone can help you.
@IPW : you can as well check what's the number/name of your old JCV file... the new one, should be quite the same![]()
If you are updating maps using a Garmin process such as liferime maps, the additions filea are automatically updated. If you are trying to update yourself you must update them yourself with the proper downloaded files.
You simply replace all the old ones (ASR, SRX, DB) with the new ones with simple file deletes and copies.
Great Effort Man.
Many thanks
Alsaber
