Thank you for time and value answer
I have two questions please:
1. Is JCV file for the same map coverage can work with all of the versions for the same map.
Means JCV file of CN Europe 2011.4 can work with CN Europe of 2012.2, and vice versa.
Definitely NOT. JCV files are linked to a specific release aqnd will work only with that version.
2.
The JCV files can be use in all the devices that support this features, even if are not the same models,
Are the JCV Files of different resolutions can jump between the models and work????
Means JCV file of nuvi 37xx (high resolution photoreal) 681Mb can work in nuvi 765 (Photoreal) 317Mb with low resolution and vice visa.
They will generally work (will display on screen) but not always as expected. They may display as the wrong size or aspect ratio when used in the GPS they were not intended for. There are MANY JCV file variants released with each map release and I think the only way to be 100% sure is to try them and see (very simple to do). I know anything that works in a 765 will also work 100% correctly in a 14xx and vica versa.
