Page 3 of 13 FirstFirst 12345 ... LastLast
Results 21 to 30 of 123
Like Tree66Likes
Thread: GARMIN ADDITIONS FILES (ASR, G2S, DB, 3D...) What & How to update.
  1. #21
    lgmge is offline Lance Corporal
    95
    Re: Where to put the JCV file?
    Put the JCV file in \Garmin\JCV
  2. #22
    rajvosa's Avatar
    rajvosa is offline Major
    Oct 2011
    827
    39
    Quote Originally Posted by wggutierrez View Post
    I was able to download a JCV folder with a JCV file inside. I think, this is from a nuvi 1360t unit.
    Can i get this junction view to work on my Nuvi 1390t unit? Where do i put the JCV file?
    Use Search
    Answer to your question:
    READ RULES BEFORE POST....
  3. #23
    Tiger is online now Major
    936
    Re: GARMIN ADDITIONS FILES (ASR, G2S, DB, 3D...) What & How to update.
    Quote Originally Posted by Vasili View Post
    Ok I will try that and see if something shows up.
    Thansk for you time.
    Edit:
    junction view is working fine, after all. How do I change the view mode to split screen showing the navigation info and the junction view at the same time. On the nuvi 775 when the junction view pops up it's full screen.
    You can't get spit screen Junction View on a 7x5 model.
  4. #24
    Mar 2011
    I have issue with nuRoute TrafficTrend on my 3790T.
    After I copied new g2s and db (2012.30) files on map screen when is route suggested it reset device when try to tap on it.
    Everything else working just fine asr, jvc ...
  5. #25
    cat2115 is offline Sergeant
    Nov 2011
    47
    Hi, will the TrafficTrends & MyTrends, JCV, gmap3d, and gmaptz work with nuvi 760? thx
  6. #26
    Kor@l's Avatar
    Kor@l is offline Global Moderator
    1,995
    357
    No, you can update just the map.
  7. #27
    Nov 2011
    Originally Posted by Kor@l:
    Let’s see what and how to update this folder with the right files.
    Rule N 1 ALWAYS BACKUP YOUR DEVICE FILES BEFORE PROCEED.
    How can I backup my Nuvi 3790t ?
    I thank you in advance Kor@l and thank you for your post !!!
  8. #28
    Kor@l's Avatar
    1,995
    357
    Enable the view of hiden folder and files, Copy to PC all the files and folders from your device, so you can replace back if something goes wrong.
    crazedleo likes this.
  9. #29
    Rainey112 is offline Lance Corporal
    What are the .gpi files for.
    I have a Nuvi 205 and i have a file "northamerica.gpi" in the root garmin directory and i have a POI folder and it has "006D135900.gpi" file.
    Any idea what these file are for??
    I seem to remember maybe adding some POI for traffic light cameras or something like that.
    The way i understand it is the point of interest data is in the 2011.30 map image file, so i should not need to add/update a file to update the POI.
    Edit:
    Nevermind, i remember now i used POI loader and loaded some POI.
    Found info at this link in the POI section
    [INDEX] Garmin POIs
  10. #30
    Nov 2011
    Thanks for the answer very quickly Kor@l , very good idea !!!
