Page 2 of 2 FirstFirst 12
Results 11 to 13 of 13
Like Tree2Likes
Thread: nüvi 7x0/7x5 multi maps
  1. #11
    sultansaga is offline Sergeant
    31
    Re: nüvi 7x0/7x5 multi maps
    many thanks tiger its work 100000%
  2. #12
    mhalda is offline Corporal
    20
    37
    New firmware 4.40:
    Changes made from version 4.30 to 4.40:
    Fixed an error that caused the device to find no results when the user changed state or province during address searches (2010 maps only).
    Added support for a second map on an SD card.
    Fixed an error that caused the device to not find streets that were spelled with a diacritic ß, instead of ss
    Fixed an error that caused the wrong time to display on the World Clock page.
    Added the missing ?Z? on Latvian keyboards.
    Improved the accuracy of route calculations.
    Fixed an error that occasionally caused the unit to shut down.
    Fixed an error that caused the device to detect the wrong keyboard.
    Fixed an error that prevented the device from accessing certain POIs while the unit was searching.
    Fixed an error that caused the unit to display the arrival time as off by one hour when on routes that crossed time zones.
    On my Nüvi 765T on SD card now works: gmapsupp.img and gmapsup1.img
  3. The Following User Says Thank You to mhalda For This Useful Post:
  4. #13
    Tiger is offline Major
    USA
    807
    Quote Originally Posted by mhalda View Post
    New firmware 4.40:
    In looking at the title of this post.... be advised that this update applies to the 755/765 ONLY (not the 750/760)
    Further 7x5 info FYI
    On SD the following map names are recognized by a 7x5
    sd:\garmin\gmapsupp.img - a recognized SD map name
    sd:\garmin\gmapsup1.img - a recognized SD map name (but name is not recognized inside the GPS)
    sd:\garmin\gmap3d1.img - a recognized map name (either 3D buildings OR an extra map if you wish)
    Inside the 7x5 the following map names are still recognized
    gps:\garmin\gmapprom.img - a recognized map name
    gps:\garmin\gmapprom1.img - a recognized map name
    gps:\garmin\gmapsupp.img - a recognized map name
    gps:\garmin\gmap3D.img - a recognized map name (either 3D buildings OR an extra map if you wish)
  5. The Following User Says Thank You to Tiger For This Useful Post:
