Don't even consider it.
It is Chinese junk of the worst kind and the most reliable part is the packaging
If you ever get it to work it won't last. The main quality of thes units is to cause a lot of frustration
You'll find out soon enough that anything spent on this kind of equipment is just wasted
See for some more information the Double-DIN section
LinkBack URL
About LinkBacks
