Like Tree3Likes
  • 2 Post By hashima
  • 1 Post By mjumrani
Thread: Why a copied sd-card is not working in your device.
    rotop is offline Sergeant
    47
    Why a copy of an original sd-card does not work in another device?
    Start study the datasheet of a sd-card and you will find out that thera are
    6 registers located on the sd-card in a protected area.
    One register is the CID = Card identification register (128-bit)
    Page 18:
    The referred register area is about 1% in size of the sd-card and is filled with data during
    the last check and formatting on the 'factory floor'.
    Untill today all vendors of sd-cards have not made public how to reach and change this data.
    Even a bit to bit image is missing this data !!
    The CID contains specific vendor information o.a.
    MDT: Manufacturing date (12-bit, Month, Year)
    and other 5 unique fabrication data.
    For navigation sd-cards, most important is the:
    PSN = Product Serial Number (32-bit, Uniquely assigned integer)
    Here an example:
    Raw CID Bytes: 94-00-73-A2-7D-7D-10-30-30-30-30-30-4D-53-1B-00
    Product Serial Number: 7d7da273 = 2105385587 (10 digit in decimal)
    TomTom, but also Garmin use this number to make a sd-card unique.
    The navigation software reads an checks this number in combination with the device unique ID
    TomTom writes this number, encrypted, as the SDcardSerial in the ttgo.bif file
    for TomTom's Carminat devices.
    Attached ReadCID.zip This a 'read CID only' program.
    The ReadCID.exe application will only work if the memory card reader is attached
    directly to the PCI bus of your laptop. No USB type of memory card reader will have the capability to
    access the CID parameters through the USB API.
    Another PSN reader for WinCE or Windows Mobile devices:
    Card_ID.exe which can be downloaded here:
    http://rapidshare.com/files/141860398/Card_ID.exe.html
    Attached Files Attached Files
    eldelperfume is offline Lance Corporal
    Sep 2011
    22
    Re: Why a copied sd-card is not working in your device.
    Quote Originally Posted by rotop View Post
    Page 18:
    Here an example:
    por favor podrias resubir el arcchivo readcid.zip,gracias
    hashima's Avatar
    hashima is offline Command Sergeant Major
    206
    47
    aquí es.....
    chelul2007 and Mark00 like this.
  4. The Following User Says Thank You to hashima For This Useful Post:
    mjumrani is offline Private
    Dec 2011
    Quote Originally Posted by hashima View Post
    aquí es.....
    Cannot download the file. The browser shows a blank screen when I click on the link
    chelul2007 likes this.
