Thread: Connect Garmin GPS 10 to WinCE 6.0 via Bluetooth
    Hi, does any member know how to connect a bluetooth GPS Receiver (Garmin GPS 10) to WinCE 6.0? My unit is Lokatoo A1000 (Proton)
    Offcourse it is a PND so equip with internal GPS Receiver, but I just want to know whether it is possible to use my old GPS 10 to increase the reception (because it can be put on the top/roof of the car).
    I have tried to search for bluetooth manager for wince 6.0 but can not get. I assume with bluetooth manager I can pair wince with gps 10 and convert it to com port.
    Regards,
    Ferdi
  2. The Following User Says Thank You to FGan For This Useful Post:
    bjjfc's Avatar
    2,334
    327
    Re: Connect Garmin GPS 10 to WinCE 6.0 via Bluetooth
    @FGan
    r u sure ur unit has bluetooth capability built-in? if the answer is yes, maybe u can try miopocket
