The bit I followed badly-
Create a file named ADDONS with the notepad in the root of your SD card that contains these lines:
next attempt will be:[modules]
GPS = "icons/files.bmp", "", 0
[GPS]
MyGuide = "", "\\Flash Disk\\myguide\\myguide.exe"
iGO8 = "", "\\Storage Card\\iGO8\\igo8.exe"
Then copy your iGO folder on the same SD card anr you are good to go
perhaps files are not suitable as iGO Primo 1.1 QVGA 8.5.11.154123 Aug 1 2010or, for more navi software, you can use this:
[modules]
Navigation = "icons/files.bmp", "", 0
Multimedia = "", "\\storage card\\tcpmp\\player.exe""
[Navigation]
Amigo = "", "\\Storage Card\\igo_amigo\\amigo.exe"
MioMap = "", "\\Storage Card\\MioMap\\MioMap.exe"
Garmin ="","\\Storage Card\\Garmin\\RunGMXT\\Garmin.exe"
Mireo = "", "\\Storage Card\\BlackEdition\\BlackEdition.exe"
iGO8.3.4 = "", "\\Storage Card\\igo8\\igo8.exe"
[interface]
;resolution_dir="320_240" [modules]
it is 480 x 272 resolution
A bit of guidance please?
dl'ing new one
Igo Primo 480x272 with uk map for WinCE 5 ppc/pna
I wander as where I'm going wrong?
create .txt file in a root named ADDON and it gives me error- can not execute...the file on SD Card does nothing
meant to copy files to the same folder?
here's what happens (nothing):
LinkBack URL
About LinkBacks
