Results 1 to 10 of 14
Thread: Problem with maps for Becker Active 43 Talk IGO PRIMO (8.5.12.165600) licence!
    Feb 2011
    I have a problem activating the new maps of Europe for my Becker GPS. The Device is with this soft Igo 8.5.12.165600!
    After lots of reading i find that its based on Igo Primo 1.2!
    When I put the maps the device sees them but they stay an INACTIVE CONTENT?
    What shound I do??
    PLS help!
    3,132
    223
    Re: Problem with maps for Becker Active 43 Talk IGO PRIMO (8.5.12.165600) licence!
    Add this 2 license contents into your license folder and try again.
    Multiupload.com - upload your files to multiple file hosting sites!
    or
    http://www.multiupload.com/274TRNI5M0
    Feb 2011
    Its not working...
    Should i tra renaming or anything? is there any point in that ?
    3,132
    223
    Did you name the path of the maps correctly in sys.text
    If map in sdcard - Primo/content/maps
    kamoteka is offline Master Sergeant
    145
    @ophelis:
    Are you still using the original iGO Primo 8..12.165600 that came with your device? If so, you can only use the original maps that came with your device because your original iGo Primo executable is licensed to run only with those original content (maps, pois, etc).
    Use the "cured" iGo Primo exe that you can download here (from the iGo Models Listing forum) either the 9.2.1.178658, 9.2.1.179499, 9.2.1.185801, or the 9.2.0.191493.
    Feb 2011
    Quote Originally Posted by kamoteka View Post
    @ophelis:
    Yes its the original!
    Do I have to replace only the EXE ? I already tried bu it said the resolution isnt correct! Ill try some more! Thanks for the tip!
    Edit 02:55H: Its still no luck! Ive put more than 15 hours with this! Ive tried about 6 different releases and many many ways to copy, delete, modify and all kind of stuff with the files!
    only luck was with a Becker Truck release, but its an much older version and the GPS loses many functions /Bluetooth, TCM, and many others I cant remember!/ ! And when i try to mod the DATA.ZIP file or the SYS file everything crashes! Im very very tired, and even more angry now!
    Feb 2011
    Fixed!
    For those interested - i downloaded a different becker version "cured" (older ) and replaced all files - thats the only way it worked!
    All new maps are working! For the other features - i dont know, Bluetooth and TCM works though!
    The version of the soft is for model Becker Z205 - found in this forum!
    PS: Always make a backup!
    145
    @ophelis :
    Sorry this is somewhat late, but I did some research and found that 165600 build is not really a Primo 1.2 build. Anyway, I found this cured 165600 version. This might work with your original software files (if you had saved them). Just replace the .exe with this one:
    Download becky.avi here
    this is an avi file, just rename it to .exe (or rename it exactly as your original exe file name).
    space1 likes this.
    Hi, does not have anyone here a backup with Becker Active 43 talk ?
    Thanks, Peter
    gyany is offline Second Lieutenant
    Mar 2012
    A, A
    340
