Results 1 to 10 of 12
Thread: How to load IGO 8 software onto a Chinese GPS-560
    huey45 is offline Sergeant
    Jul 2011
    58
    21
    Hi Guys
    Im newbie so dont shoot me, i recently bought a Chinese GPS-560
    I THINK MADE BY ANANDA ?
    through a online retailer
    And when looking at Sys Info i get
    the following info :-
    Processor SIRF Atlas-V
    Platform 00.5.02
    App Version 110118.1516.QC01.MLC
    OS Version N110325E11032501103051130
    Nav N Go IGO 8
    8.3.2.80621
    Mar 10 2009
    Thanks in Advance
    huey45
  2. The Following User Says Thank You to huey45 For This Useful Post:
    Cosmic Blue is offline Sergeant
    32
    Re: How to load IGO 8 software onto a Chinese GPS-560
    Quote Originally Posted by huey45 View Post
    Hi Guys
    Platform 00.5.02
    Nav N Go IGO 8
    8.3.2.80621
    Mar 10 2009
    Thanks in Advance
    huey45
    are you trying to load Igo 8.0 and giving us the version information
    or is IGO already installed on your device and you are trying to get it working.
    bazzle is offline Lieutenant
    Melb Oz
    347
    33
    Would you like to update to a more current version? iGO8.3.5 etc?
    Bazzle
    Jul 2011
    Can anyone give me the latest igo software for a chinese gps? I would like U.S.A map and a New Zealand Map if possible. I think the resolution is 800 x 480
    punter999 is offline Private
    See the below thread that may be of help. Maps, Nav software [not the latest] etc
    http://gpsunderground.com/forum/igo-...-south-am.html
    Regards,
    Punter
    Jul 2011
    58
    21
    Hi Bazzle
    Sorry i was not more specific with the information i supplied
    i was looking for a guide to load a later version of Igo 8 onto
    my satnav as i already have V8.3.2.80621
    dated Mar 10 2009 loaded...
    And what to load into what folders on unit
    thanks in advance
    32
    huey45
    you would load the maps in the map folder
    POI into the POi folder
    voices in to the language folder.
    you will find all these folder on the root tree of your device.
    but first you need to upgrade the Igo to a new version before loading the various files into their folders.
    you can find igo 8.3.5 in this thread.
    iGO8.3.5.193799 27 May 2011
    Jul 2011
    58
    21
    Hi Cosmic Blue
    So I look for the latest version of IGO 8
    download it, then follow the procedure
    you describe, its not the actual unit
    just the software im upgrading ?
    huey45
  10. #9
    32
    correct it is only the software you are upgrading.
    you might have to do some tweaking to the sys.txt file if it does not display properly, we guide you through that if needed.
  11. #10
    Jul 2011
    58
    21
    Hi Cosmic Blue
    Thanks for that, i updated my old Garmin few times with confidence
    but my new Chinese GPS-560 is still a bit of a grey area
    i dont want to screw it up, is there anyway of doing a
    backup of exsisting software, to revert back too ?
    regards huey45
  1. 18th February 2012, 09:37
  2. 14th February 2012, 16:06
