Results 1 to 10 of 10
Thread: voice right or left turn,question
    bosanci28's Avatar
    bosanci28 is offline Corporal
    Jan 2011
    usa
    26
    sorry,i dont know much about this stuff...
    i have primo 1.2 ,and what file do i need to make the gps to say:
    " in 1000 ft make right turn on watt ave!" like to say the name of the street !?
    is that called TTS ?
    and if yes where i can find that file for usa,ca., wince 6
    thank you very much for any help!
    duffer is offline Lieutenant
    Jun 2011
    436
    Re: voice right or left turn,question
    Quote Originally Posted by bosanci28 View Post
    You don't need an additional file. It should have been in the Primo download unless it was with a different language only. You want English [US]. BTW, TTS is text-to-speech and that's what says the street names.
    bosanci28's Avatar
    Jan 2011
    usa
    26
    hi, and thanks for replying!
    i downloaded this here,and is his ver 1.2 primo?,or is a different version?,i asked there to to make sure with what i am working.
    anyway,about those TTS ,i have some primo files from some time ago ,now i dont know if i can use those, this files have this names:
    >Voice_Eng-us-m4
    >Voice_Eng-us-f1
    are this the right files that i should have in the voice folder for TTS ? for usa? wince6?
    thank you friend...
    951
    >Voice_Eng-us-m4
    >Voice_Eng-us-f1
    thank you friend...
    Those are not TTS voices. A TTS voice will look like;
    Voice_TTS-nua-eng-us-f1-lua-dri40-vssq5f22.zip (nuance voice)
    or
    Voice_TTS-loq-eng-us-f1.zip (loquendo voice)
    bosanci28's Avatar
    Jan 2011
    usa
    26
    thanks for clarifying that for me!
    i found some for usa that it works i see ,here is a link if someone needs it.
    thank you.
    951
    thank you.
    Your welcome. With regard to your first question, since the poster has not identified the version, there is no way of telling until you install it and look at More>Help>About.
    bosanci28's Avatar
    Jan 2011
    usa
    26
    ok,i will do that to find out,the version.
    thanks
    bosanci28's Avatar
    Jan 2011
    usa
    26
    Quote Originally Posted by dohcacr View Post
    may i ask other question?
    is this the right file "USA_Indiana.3dl" that i have in buildings folder ? as i did not see those buildings when i was driving!
    thank you very much friend for any advice!
    (my ver that i have : igo primo 9.2.1.178658 feb 9-2011)
    951
    That is the right file to display buildings in Indiana, but you will find that only major cities actually have buildings that will display. If you set up a route within a major city, specifically in the downtown area, that has the most exalted status (ie, San Francisco Financial district), and then run a simulation of that route, you'll see what I mean. You might also want to try to simulate a route to the "brickyard" in Indianapolis. That might actually have a representation in the building file.
    bosanci28's Avatar
    Jan 2011
    usa
    26
    ok,i understand now,
    thank you so much for explaining to me!.
