Page 1 of 5 123 ... LastLast
Results 1 to 10 of 41
Thread: Low Memory using iGo Primo
    slayer2k is offline Corporal
    26
    47
    i use iGo Primo on a North Cross es 515, 64 mb SDram. Every time i open Primo i get meory low. Can somebody help me giving correct sys.txt to put in Primo directory.
    Tks a lot.
    100
    Re: Low Memory using iGo Primo
    is it out of memory error?
    does it get out of the program?
    do you have igo8 or amigo on the same sdcard?
    sys.txt entry
    [debug]
    cache=2048
    reserve_memory=209715
    if you have igo8 or amigo on the same sdcars and you did not fix the content folder then use this entry:
    [folders]
    has_secondary_root=0
    or rename "igo8" folder to "igo8.3" and "amigo" folder to "new amigo"
    hope it will help you
    Quote Originally Posted by slayer2k View Post
    Tks a lot.
    Had the same problem with Fujitsu-Siemens Pocket LOOX.
    Try to modify HighRes=1 to HighRes=0 at [Rawdisplay] (and the screen_x/screen_y too with stretch=1, if your native screen resolution is more than 400x240)
    chas521 is offline Banned
    83
    Memory problems are usually caused because you have too much content trying to load when the program is booting up.
    Bananengourmet is offline Sergeant
    58
    Remove all maps you don't need, all unneeded lang and voice, DEM, histspeed, skins and maybe buildings/poi.
    If your data.zip contains more than your resolution delete all the resolutions not needed.
    Still Primo will not be very fast but at least sufficient.
    Works on my Binatone X430 with 64 MB only.
    959
    Tks a lot.
    Add to your sys.txt;
    [debug]
    max_memory=35000000
    reserve_memory=1700000
    cache=600000
    Works for me!
    junker9 is offline Lance Corporal
    May 2011
    If I map out a long distance, it can take 10 minutes for Primo to load. Long time to calculate, then a long time to load on restart. I assume it's because of low memory. Could it be the TTS Voices that are slowing things down?
    959
    The lack of memory could be part of the problem, but when a GPS is running as slow as you describe, I would suspect a slow cpu. In any event this tool will let you know what resources are available. It will tell you the type of cpu, and speed, but you will have to do some research to determine how that compares to the cpus being used in todays gpses. What kind of GPS are you using?
    May 2011
    Thanks for your reply.
    I know my specs. I am using a 528Mhz ARM processor with 64kb of RAM. I use a piece of software that keeps track of Mhz and steps it up or down depending on the load. The higher the load, the higher the Hz. I think it only ran at 128 when Primo was working so hard.
    In the interest of science, I can try stepping it up to 528 manually and see if that improves things. Please stand by.
    May 2011
    I guess we are not allowed to edit our posts here.
    I tried to set up a destination about 800 miles away and turned the CPU on "high."
    Put in the State okay!
    Put in the City okay!
    Street took about 2 minutes, then okay!
    Put in the street number okay!
    Displayed the location on the map, okay!
    Then poked "Select" and it all ground to a halt.
    It's been a few minutes and things are still unresponsive here.
    I am downloading the tool as I wait, but this is a Samsung SCH-I730 phone running WM5.
    The phone has GPS built-in, but the company will not allow access to it by other programs, so I am using a Bluetooth Puck. A Globalsat BT-359.
