I installed a version of igo android iGOMyWay_v8.4.3.179971 to my 7" tablet, and I cannot get it to fit the screen properly. The right side is cut off about 1 cm or so. I have tried several settings in the sys.txt to get it to fit, and nothing seems to work . The error I get the most is "User resolution interface [YYY x YYY] is not supported or comatible skin can not be found".
Any ideas how to fit it properly?
My tablet resolution is 800x600
