Thread: The way to edit keyboard in primo
    100
    the hebrew keyboard is not right it is because the data.zip and not the lang file.
    The way to edit the keyboard is to double click on the data.zip (not unzip it) get into DATA.ZIP\ui_igo9\common
    edit keyboard.ini file
    for hebrew:
    [panel]
    name= "Hebrew"
    layer= "ui_kbd_10_10_9"
    keys= "יטחזוהדגבארקצפעסנמלכתשםןצףך "
    altkeys= "1234567890כךמ/.,’-()?!*@&# :$€ "
    lang= "hebrew"
    altlabel= "אבג"
    type=3
    save, exit and exit winrar. the file will be saved in the data.zip file
  2. The Following 3 Users Say Thank You to miomoshe For This Useful Post:
    galeting is offline Lance Corporal
    Igo primo language ...keyboard
    I need to IGO PRIMO keyboard configuration for the Serbian language, if someone has let me help .... thanks in advance
    100
    Re: Igo primo language ...keyboard
    look here : you will be able to do it yourself.
    dxdy is offline Staff Sergeant
    67
    croatian and serbian language with gurjon skin suported + keyboard
    Re: The way to edit keyboard in primo
    thanks man.............
    thanks man.........
