Results 1 to 8 of 8
Thread: Igo Primo Android No Sound At all.
    nitinule's Avatar
    nitinule is offline Sergeant First Class
    122
    48
    Dear Friends...
    I have Chinese Cybernav Mini and I have iGo Primo 9.6.7.235654 May 16 2012 .. working very fine on Android 2.3.4 .. Resolution 800X4xx
    The Problem is ther is no touch sound or Navigation voice or no "Drive Safely" Dialog while trying to change British English or US English Voice. Its total silent. And the English Voices are there which are not TTS.
    Can sys.txt can solve this problem??? I dont have that file saved anywhere in the iGo Folder..
    Can someone guide please.. I have same application working on Wince6 China device and I get proper voice instructions.. all OK. tried overwriting many files in Android device but no luck.
    Help please .. I want voice instruction working on this.
    regards
    Nitin
    3,132
    223
    Re: Igo Primo Android No Sound At all.
    Try this sys.txt - save it root folder
    [project]
    name="igo_android"
    [device]
    type="android"
    [rawdisplay]
    screen_xy="800_480:854x442/480x800"
    highres=0
    double_screen=0
    show_cursor=0
    combine_dirty=1
    [interface]
    driveralert_sound="1"
    laneinfo_signpost_enabled="1"
    recalc_voice="1"
    [folders]
    sdcardpath="/mnt/sdcard"
    linked_root_list="/sdcard2/iGO /sdcard/iGO /sdcard/sd/iGO /sdcard/external_sd/iGO /mnt/sdcard/iGO /mnt/sd/iGO /mnt/iGO /storage/iGO /mnt/sdcard/sd/iGO /mnt/sdcard/external_sd/iGO"
    has_secondary_root=1
    secondary_app="/sdcard/iGO"
    user_backup_path="/sdcard/iGO"
    data="/sdcard/iGO"
    content="/sdcard/iGO/content"
    [services]
    ;server_addr="https://android.naviextras.com/"
    factory_license_code_filename="%sdcard%/iGO/prepaid"
    ;software_download_location="https://android.naviextras.com/dlapk"
    delete_callstack=1
    [tmc-http]
    enabled=0
    [sound.announcer]
    ;gps_signal_lost=0
    gps_disconnected=0
    [android]
    logcat_file_delay=50
    [gps]
    location_net=0
    check_gps_timestamp = 1
    background_navigation=1
    send_init=0
    set_messages=0
    sent_init_type=0
    [feature]
    tmc_event_coloring=1
    [sound]
    auto_mute="0"
    os_muted="0"
    queue_length="200"
    ding="0"
    csv_voice_enabled="1"
    button_sound="button_on"
    [navigation]
    use_duration_for_tunnel=1
    stop_at_tunnel_end=1
    autoreplan_action="AUTO"
    sim_speed_factor="3.0"
    gps_pos_to_road="1"
    show_current_city="1"
    show_countrychange="1"
    gps_pos_to_road="1"
    [tts]
    tts_eta=1
    tts_buffer=131072
    tts_logics=3
    priority="HIGH"
    announce_exit_directions=1
    supress_Prepare_to=1
    supress_straight=1
    always_say_road_names=3
    ;always_say_road_names=1
    announce_street_name=1
    skip_exit_numbers=0 ; 0, 1 or 2
    [debug]
    imei=000000000000000
    skip_eula=1
    sound_q_length=200
    tts_min_ready_wav= 1
    tts_getaway_time=100
    tts_expected_engine_delay=400
    enable_roadshadow=1
    skip_eula=1
    getupdates=0
    show_performance=0
    reserve_memory=2097152
    cache=262144
    adjust_pen_position=0
    vetorender=0
    show_oneway=1
    show_oneway_3d=1
    show_speed_limit=1
    show_lane_info=1
    enable_roadshadow=1
    show_arrows_on_route=1
    speedcam_enabled=1
    supress_highway_enter=1
    supress_trivial_left=1
    supress_trivial_right=1
    double_pixel_mode=2
    render_without_focus=1
    [speedcam]
    enable_at_startup=1
    [warning]
    approach_beep_distances=8,25,50
    warn_distances=120:500;110:400;90:350;70:300;50:25 0;40:150
    speedcam_max_lookahead=500
    activated_spoken_type=speech
    activated_speech="Atenção, Radar Fixo logo à frente, diminua a velocidade."
    activated_min_speech_repeat_delay=-1
    min_frc=-1
    approach_beep_distances="1,25,30,50,100"
    approach_beep_sound="!alert5"
    approach_beep_spoken_type=2
    speedcam_max_angle=10
    speedcam_maxdistance_from_road=10
    speedcam_enabled=1
    speedcam_warning=1
    speedlimit_warning_visual=1
    speedlimit_warning_voice=1
    speedcam_visualtype=1
    speedcam_soundtype=1
    speedcam_soundtype_4=2
    speak_tts_only=0
    speedwarn_alt_builtup_based=1
    speedwarn_alt_limit=1
    speedwarn_alt_toltype=1
    speedwarn_tolerance=110
    speedwarn_toltype=1
    [3d_config]
    show_guidance_strip="1"
    disable_roadsign_navigation_mode="1"
    rotated_roadsigns="1"
    use_all_building_textures="1"
    fade_distance_for_car="50"
    fade_distance_for_guidance_arrow="500"
    fade_overlap_tolerance="0"
    [poi]
    multipoi=1
    [keyboard]
    panel_alpha="Default"
    panel_numeric="Numbers"
    ;panel_geo="Geocoord"
    [3d]
    road_shield=1
    road_box=1
    planned_route_contour_width=1
    planned_route_track_contour_width=1
    planned_route_track_width=5
    [3d_config]
    disable_roadsign_navigation_mode=0
    [map]
    3d_tunnels=1
    [smartzoom]
    auto_follow_time=30
    restore_smartzoom_on=0
    auto_smartzoom_time=30
    overview=0
    auto_follow_on=0
    ;overview_zoomlevel=3000
    enabled=0
    maxangle=85
    minangle=85
    ;maxzoom2d=1000
    enabled2d=1
    zoom_after_find=0
    nitinule's Avatar
    122
    48
    Thanks a lot Arion for your Help.. But I did Flash my device with MMC and reset .with ROM Provided by the Chinese manufacturer.
    Now its perfect..
    Thanks anyways..
    Regards
    Aug 2012
    What does it mean: flash with MMC?
    I have same problem.. I dont have sound and the sound indicator goes to minimum when selecting voices.
    The other thing: when installing igo primo, it works very well besides the audio. Exiting from program and starting for example 1 minute after - program does not start. It says: cfg problem or resolution problem etc. When clearing data from nand flash, it reinstalls itsself and after that it works (with no audio). Clearing data does not delete favourites or other history.
    Can You help me with getting the sound and getting the igo primo running properly (so that i dont have to clear nand or something like that).
    Jussi
    nitinule's Avatar
    122
    48
    Dude.. I tried everything but the sound was not coming bacl.. Not even the touch screen tap sound was ther... But at the same time the other Apps where perfect so that means there was no problem with Device speaker.. But still i flashed my device with original ROM and all is fine
    regards
    janch is offline Sergeant First Class
    116
    24
    your problem is hidden in .apk file in folder \res\raw\sys.txt, because there is one entry in sys file which is causing sound problems on some devices! I had the same problem when I installed Primo on my WayteQ xTAB 50 GPS. So You have to delete this line:
    [sound]
    csv_voice_enabled=1
    ding_muted=0
    dev_channels=2
    then you have to install Primo with modified apk file again and soud is O.K!
    If you can't manage this by yourself, please feel free and contact me on private and I can send you modified apk file.
    regards,
    Janch
  7. The Following 4 Users Say Thank You to janch For This Useful Post:
    Apr 2011
    29
    Quote Originally Posted by janch View Post
    [sound]
    csv_voice_enabled=1
    ding_muted=0
    dev_channels=2
    regards,
    Janch
    That fixed my prob perfectly! Thanks Man!
    Jan 2013
    hi,
    I also have a Wayteq xtab-50 GPS. It"s a new one with Android 4.0.3
    Igo is all fine even the sound: no voice, no voice TTS, no "clic".
    I re install Igo (9.6.7) after learning this post... But impossible to change the sys.txt in the apk file --> impossible to install the soft.
    When it's installing, I change the sys.txt as discribe but nothing (so There was no [Sound] line in it (??)
    I can delete the sys.txt, the apk and the save folder but it's always the same Igo works fine but ... No sound, no voice...It seems using an old sys.txt but I don'know where ii it to delete it before re install?
    An idea to help me??? I try many things, but....no way...
    Thank you for your help
