Results 1 to 8 of 8
Thread: iGO PRIMO 2.0 i3 480 x 272 resolution
    maa1506 is offline Staff Sergeant
    61
    63
    Does anyone know if the new I3 version of primo will run on a device with a resolution of 480*272 (Navman) Currently running Primo 2 on it which runs fine, however I3 will not start up. I may be wrong but I am guessing it's something to do with the resolution as I have I3 running on 7" satnav which runs fine.
    Any suggestions appreciated?
  2. The Following 2 Users Say Thank You to maa1506 For This Useful Post:
    spriggan's Avatar
    spriggan is offline Major
    760
    40
    Re: iGO PRIMO 2.0 i3 480 x 272 resolution
    look at your PM I send you new data zip with resolution 480 x 272
  4. The Following User Says Thank You to spriggan For This Useful Post:
  5. #3
    61
    63
    Thanks, much appreciated, got the file, will give it go within the next few days & report back
  6. #4
    61
    63
    Worked perfectly now have I3 working ok on my Navman
  7. #5
    spriggan's Avatar
    760
    40
    cool glad it works
  8. #6
    Sep 2011
    Hi, I have Asus A639, when I start IGo i3 program non start, and write "uSER INTERFACE RESOLUTION (240X320) NON SUppORTED OR COMPATIBLE SKIN CAN NOT FIND..."
    Can you help me?
  9. #7
    Feb 2013
    I was wondering could I get the same file for the 480X272 resolution because i have the same problem got the iGO PRIMO 2.0 i3 but cannot run it.
  10. #8
    Feb 2013
    I made a mistake in my previous post the device runs on 320 x 240 reslutino
