Hi i have a problem with igo8.3 when i try to start the program load till to languages and then nothing
goes back to the main screen.... please if you know why help me.... thanks....
i dont know how i fix this my sys.txt it's that..what i should be change.. sorry for my english type. i am from greece,and thanks..
[folders]
has_secondary_root=0[interface]
skin="ui_igo8_da"
[3d]
fade_distance_for_car=0[folders]
app="%SDCARD%/iGO8"
fade_distance_for_guidance_arrow=0[tts]
tts_buffer=131072
announce_exit_directions=1
tts_logics=3
priority="HIGH"
always_say_road_names=1
announce_street_name=1
skip_exit_numbers=0
[dynamiccompressor]
compressor=1
ratio=9
gain=9
[sound]
ding=0
queue_length=200
mute_os_key=1
pause_mp3_sooner=1
[debug]
sound_q_length=200
tts_min_ready_wav= 1
tts_getaway_time=100
tts_expected_engine_delay=400[device]
type="HTC Touch HD T8282"
sdcard_dsk_num=7[interface]
skin="ui_igo8_da"[defaults]
mainroadness=60
shortessness=50
simplificationness=40
[route]
correctness=85
planned_route_weight=4
scenic_highway_weight=4
scenic_scenic_weight=2
tmc_weight=6[interface]
maxzoom2d=6000000
show_exit=1
defaulttilt3d=7600
[map]
3d_max_tiltlevel=10000[map]
2dheadup=1
3d_max_zoomlevel=3000
3d_min_zoomlevel=40
3d_max_zfar=2000
[smartzoom]
minangle=0
maxangle=80[warning]
pedestrian_warning=0
speedcam_visualtype=1
speedcam_soundtype=1
speedcam_warning=1
speedlimit_warning_voice=1
speedlimit_warning_visual=1
speedwarn_tolerance=110
speedlimit_warning=1[debug]
earth=1[3d_config]
disable_roadsign_navigation_mode=0[poi]
[map]
2dheadup=1[route]
correctness=100[device]
Where did you get that sys.txt and what version of iGO8 are you using? First of all, it's huge and is probably causing a lot of your problems. Also, what is the resolution for your device?
Can someone here help him with a proper sys.txt for iGO8?
Here is what I am using. Hope this helps? I don't think it is any smaller but it works in my Mio c230 and C320.
[folders]
app="%SDCARD%/iGO8"
[debug]
enable_roadshadow=1
show_residentonly=1
enable_roadsign=1
enable_landmark_occlusion=1
show_oneway_3d=1
show_oneway=1
show_gps_pos=1
show_signpost=1
background_navigation=1
screen_calibration=1
skip_eula=1
;max_memory=25000000
[interface]
maxzoom2d=6000000
show_exit=1
shutdown_time=0
defaulttilt3d=7600
[map]
2dheadup=1
3d_max_tiltlevel=7500
3d_min_zoomlevel=40
3d_max_zfar=2000
stop_rotate_on_map_move=1
inertia_on_map_move=1
follow_gps=1
2dheadup=1
[poi]
poi_show_all_btn=1
poi_labels=1
show_poi_boundingrects=1
show_poi_areas=1
[navigation]
show_current_city=1
show_countrychange=1
autoreplan_action="AUTO"
gps_pos_to_road=1
[smartzoom]
minangle=80
maxangle=80
[msnd]
enabled=0
[map]
3d_scale_carmodel=1
3dcarsizemin=8000
3dcarsizemax=8000
3dcarsizemul=10000
[tts]
tts_buffer=131072
tts_logics=3
priority="HIGH"
skip_exit_numbers=0
[sound]
ding=0
queue_length=200
[3d_config]
i run the igo8.3,the device is mls 4810. I try to run the program without sys.txt and again the same problem stop's to the languages. I think the resolution of device is 480_272.. the program run perfect, the only think i do it's update to speedcameras,
after that i have that problem,i try to delete the speedcameras after that but nothing, i dont know what to do...... but thanks for your answers again...
Change / check [GPS] baud and port to yours AND resolution under [Raw Display] and [Interface]
[folders]
app="%SDCARD%/iGO8"
[debug]
enable_roadshadow=1
show_residentonly=1
enable_roadsign=1
show_oneway_3d=1
show_oneway=1
show_gps_pos=1
show_signpost=1
skip_eula=1
traincrossing=1
supress_trivial_left=0
supress_trivial_right=0
[gps]
port="2"
baud="9600"
delay="500"
[interface]
maxzoom2d=6000000
show_exit=1
shutdown_time=0
defaulttilt3d=7600
vga=0
resolution_dir="800_480"
skin="ui_igo8"
[map]
2dheadup=1
3d_min_zoomlevel=40
3d_max_zfar=2000
follow_gps=1
2dheadup=1
[poi]
poi_show_all_btn=1
poi_labels=1
show_poi_areas=1
enable_pois_before_0802017=1
[navigation]
show_current_city=1
gps_pos_to_road=1
sim_speed_factor=3.0
[smartzoom]
minangle=0
maxangle=80
[msnd]
enabled=0
[map]
3d_scale_carmodel=1
3dcarsizemul=10000
3dcarsizemin=7000
3dcarsizemax=8000
[rawdisplay]
class="landscape"
highres=0
screen_x=800
screen_y=480
[sound]
ding=1 ;=0 no ding
queue_length=200
[route]
correctness=80
[tts]
tts_buffer=131072
tts_logics=3
priority="HIGH"
skip_exit_numbers=0
[3d_config]
roadsign_lines_per_screen=12
disable_roadsign_navigation_mode=1 ;=0 balloon =1 in street
[tmc]
auto_detour_calc="0"
announce_total_route="1"
ainit_on_startup="1"
new_event_recalc_timeout="5"
changed_event_recalc_timeout="5"
tmc_weight="6"
3d_tmc_road_extra_width="200"
show_tmc="1"
tmc_all_stations="1"
[traffic.settings]
;detour_acceptance_mode="0" ;no detour proposed in case of traffic jam
;detour_acceptance_mode="1" ;detour automatic
detour_acceptance_mode="2" ;detour proposed (must be accepted)
[warning]
speedcam_max_lookahead=200
speedcam_max_angle=20
speedcam_snap_distance=200
speedcam_maxdistance_from_road=10
[dynamiccompressor]
compressor=1
a0=56806
thrs=24703
ratio=8
gain=10
Last edited by bazzle; 28th November 2012 at 15:48. Reason: added bit reminded by Duffer
my friend's,thanks a lot for your answer's,i fix it,the problem was a languages zip. i change it and now run perfect... thanks again and again.. always we must to keep a backup....i learn now friend's...............
