I have everything working with my 8.3.5. What I did was to ONLY put the .fbl files in content\map - not everything else.
Upgraded from 2011.Q4 to 2012.Q2 and lost all ability to change map color profiles. Tried on 2 units and dos emulator. Went back to 2011.Q4 and all is well. Anyone?
Exactly what I did. Didn't even change the poi's.
Using 8.3.2.96054, it's the only version that works on these old units that permits resume after power loss. Tried 8.3.4 and 8.3.5, all give a black background. FYI, I use 2D only. Surprising when I deleted the save folder and booted up 3D mode the maps rendered correctly. Took out all map settings in the sys.txt file, didn't help. I have a Magellan 1700 and a DragonPearl 5", Chinese Win CE units. I have Primo on a nexus7 and hate it.
The maps on my PC Emulator were not working correctly and by removing the NT basemap I cured the problem. Looking back this is the cure for all my troubles, ditch the basemap or find a old one that works. Do we really need a basemap?
Basemap: Not really. Unless you go from continent to continent. It only shows the outline of the different continents. You can't navigate with it.
