Results 1 to 8 of 8
Thread: 6-7 digit Post Codes
    domelsnake is offline Corporal
    Dec 2010
    18
    Hi guys
    Anyone had this issue before?
    Can not put 6-7 digit post codes in my iGO Primo (9.6.5) for some reason (United Kingdom).
    It just takes first 3 and then shows me couple examples but not the one which I am looking for.
    Not too sure if this is the map, software or settings issue.
    Change TomTom (Teleatals) maps to Navteq and still the same.
    Any ideas?
    Dec 2010
    18
    Re: 6-7 digit Post Codes
    All sorted...
    Added couple licences to the "licence" folder and all working fine now.
    Dec 2012
    Hi!
    I have a similar problem. IGO primo 9.6.7.235654
    Swedish postal code looks like this: 143 30 - with a space
    when I am search postcode, for a space behind the third digit can no longer enter the remaining two digits, but it is strange that the bottom of the results can be opened.
    Please help!
    BR
    Raitis
    May 2011
    Hi
    What do you mean by Added couple licences to the "licence" folder where could i get the licenses from as i have the same problem. Any help would be appreciated
    Regards
    May 2011
    All sorted with another map ta
    say1anonly is offline Sergeant
    Jan 2013
    39
    can i run this on any gps
    Sep 2011
    Quote Originally Posted by Hondaman View Post
    Would you mind to share how your do it? It only allowed to to key-in 2 digit.
    May 2011
    It might be a silly question but are u putting a space between the post code like this bb7 4nd. im not sure if thats what i was doing wrong but i used another map before i tried putting the space on the old map.
