Thread: mio igo satellite problem
    Clonimus74 is offline Lance Corporal
    hi
    I unlocked my mio moov 300, originally running miomap 2008
    I installed igo in the sd card and it works fine
    the problem is it doesn't find any satellites (miomap works fine)
    does anybody have any suggestions?
    thank you
    Re: mio igo satellite problem
    Check what your GPS was running on before, The baud and the rate, then goto igo and add to the sys.txt
    [gps]
    port=7
    baud=4800
    Change the Red to your numbers. Should find satellites then
    in which file in the miomap folder do I find the boud and port numbers?
    couldn't find sys file in miomap folder
    the sys file in igo has only these lines:
    ;[device]
    ;type="HTC Touch HD T8282"
    [folders]
    app="%SDCARD%/iGO8"
    [interface]
    maxzoom2d=6000000
    show_exit=1
    thank you for your help
    Not quite sure but try this
    [gps]
    port=2
    baud=57600
    Searching google someone said that's there's so it's a possibility that would be yours too, add it to sys.txt and try to find some satellites
    thank you it works!!!
    No probs, enjoy.
