Thread: igo primo on car gps stereo causing flat battery
    say1anonly is offline Sergeant
    Jan 2013
    39
    so yeah this is the unit i have Car GPS Navigation System with Bluetooth 1-DIN DVD ++ for sale with igo primo and its keep running in background every time i turn my car on.but now if i don't use car for 2nights....battery is all gone....please help me i really like this program
    janch is online now Sergeant First Class
    120
    26
    Re: igo primo on car gps stereo causing flat battery
    Don't you have an exit button in iGO Primo? If not, you should add this line in sys file which you can find in Primo dir on your SD:
    [interface]
    show_exit=1
    Jan 2013
    39
    i have this already.tho i can quit from selecting dvd tv etc is this be the same thing and will it stop draining car battery
    bazzle is offline Second Lieutenant
    Melb Oz
    342
    31
    Its not iGO its the car unit not turning off. Press the on/off button long press.
    Bazzle
    Jan 2013
    39
    oh that sounds more like it.Tho unit go off when i turn ignition off or did you mean press off before turning engine off
    Melb Oz
    342
    31
    If the Unit is Canbus compatible it shoild turn off with ign. If not long press as some cars Aux stays on.
    Bazzle
