Results 1 to 8 of 8
Thread: Compass Problems
    Compass Problems
    Hi folks new guy in these forums looking for a bit of help I have
    NAV N GO iGO9
    8.3.4.117940
    Im using it on a HTC HD2
    I hope that's enough info for you, i have a slight problem my compass is in Swedish it doesn't have N E S W on it I have like A NA etc, is there a way to change it to a uk compass???
    Essex UK
    209
    Re: Compass Problems
    Do you have a skin installed at all, iv just checked mine an its english, however im using the GJ5.9(DVS1&gurjon) mod. with iGoskinwizard
    Hi Matty thanks for the reply, erm no i dont seem to have, if i recall i got this from the net and just added uk maps to it, in my ig0 8 folder i have
    Audio
    Content
    Custom
    Defaults
    License
    Save
    Branding
    Data
    Igo 8 .exe
    Tahoma
    Tahomabd
    and thats it i couldn't find anything related to what you said anychance i could borrow your skin to see if it makes a diff mate
    Essex UK
    209
    If I get a chance I will upload it for you tomorrow, id give you the link but unfortunately i tried that many skins im unsure where it was from.
    Im also using 8.3.4.102680 and not the same version as you.
    bazzle is offline Lieutenant
    Melb Oz
    347
    33
    Maybe here?
    Bazzle
    Essex UK
    209
    Quote Originally Posted by bazzle View Post
    Maybe here?
    Bazzle
    Youd think so but his downloads go from 4.6 to 5.11 with nothing inbetween and mines definitely 5.9
    Essex UK
    209
    And here it is, this is the skin im using and it seems to be one of the best skins iv found for my HD2.
    works perfectly and isnt to complicated.
    going to try now thank you
