Thread: need help with IGO 8.3
    Hi all
    i have installed igo 8.3 on my chinese pna everything works, but the problem i am having is that the position of the car on the screen is behind the actual position on the road . so much that when the gps tells me to turn left i have allready past the road and need to do a u turn!! is there a way to adjust this as amigo installed on the same pna works great as well as an older version of igo.
    100
    Re: need help with IGO 8.3
    try to reset the device
    tried that but no difference , but thanks for the quick reply. i think that it must be something to do with the particular version as i can change the gps system as i have amigo , igo 8.3 and an older version as well on the sd card and only 8.3 has the lagging position. is there something i can change in the syst text file
    carpenter940 is offline Lance Corporal
    A little late in my answer but I saw this on another site today.and read first post.
    Last edited by matty538; 26th June 2010 at 08:52. Reason: Links to other forums not allowed
