Like Tree2Likes
  • 2 Post By xTmDarren
Thread: Igo8 on sony NV-U73T Help please!
    Unhappy Igo8 on sony NV-U73T Help please!
    This is the instructions I see everywhere..
    --- Rename the original file Mounted Volume\Sony\nav-u\nav-u.exe on the pna to nav-u2.exe
    To go back to Sony software, rename the saved nav-u2.exe to nav-u.exe
    Unzip the download file to for e.g. c:\Mounted Volume
    Copy c:\Mounted Volume to the pna with active sync, use Windows xp with Active sync 4.5 and not Vista.
    Reset the pna and look.
    You have to fill the content folder with your own maps , voices etc.
    This is the structure of the folders:
    Mounted Volume
    ---Primo
    ¦ +---content
    ¦ ¦ +---building
    ¦ ¦ +---dem
    ¦ ¦ +---lang
    ¦ ¦ +---map
    ¦ ¦ +---phoneme
    ¦ ¦ +---poi
    ¦ ¦ +---scheme
    ¦ ¦ +---speedcam
    ¦ ¦ +---texture
    ¦ ¦ +---userdata
    ¦ ¦ +---voice
    ¦ +---defaults
    ¦ +---license
    ---Sony
    >>> +---nav-u
    But when I go into my nav-u this is the only folders I see..
    NAV_U
    -NV01N001
    --CONTENTS
    ---SOUND
    ---TMC
    --MAPS
    and I cant find nav-u.exe anywhere when I open it as a virtual drive..
    what can I do to make this work? is it bc i am opening it up as a virtual drive.. or bc im running windows 7... or bc I have the lastest updates on my nv-u73t.. ??? lol
    Thanks in advance...
    rubina and Wanja like this.
    Zeppelin is offline Corporal
    18
    Re: Igo8 on sony NV-U73T Help please!
    Have you got 'show hidden files' ticked? i.e. in xp anyway its tools>folder options>view and then tick show hidden files.
    Just a thought, good luck, working fine on my 93
    davenetv is offline Corporal
    NE Eng
    26
    29
    try this it works on the U50
    you will need to put in new map and so on but might be worth a try good luck
    Dave.....
    does anyone have a more easily understandable set of instructions to put igo8 onto a sony nv-u70?
    because every website has the same set as the op described and its impossible to follow
    cheers
    Mar 2012
    Did you what was the problem?
    Mar 2012
    Did you finally found what was the problem???
