I have been running IGO8.3 on a bricked Magellan for some time and use it to generate tracks that I have ridden. I normally use RouteConverter to read and modify the "Tracxxx.trk" files that are generated. My question is "has anybody figured out how to rename the modified files so that they retain the the new file name when reloaded back in to the save/tracks/ folder." What is happening is that when I name the modifyed tracks and reload them they show up only as "Title" on the (Menu/Manage/Track Logs/) screen. I then have to rename them within IGO which works for 1 or 2 tracks but is time consuming with multiple tracks. May not be a simple solution but thought this may be the forum to ask.
