Thread: Is it possible to install iGo8 on a Magellan Roadmate 1440?
    Greetings:
    Is it possible to install iGo8 Amigo or Primo TTS US on Roadmate 1440? If so, which version will work best?
    Re: Is it possible to install iGo8 on a Magellan Roadmate 1440?
    BUMP! I would like to know this to is there a way to run from internal storage ? as opposed to sd ? does some one have a tut or a link to a specific thread, i used the search and this is the only thread i found
    canscot05 is offline Corporal
    16
    Have a look at the install on the Magellan 3100, the process is simliar. You can run from SD using Igo8 renamed as iboot.exe, or via softbutton, or install Igo8 into HDD and run it from there by modifying startup.xml, or naming igo8 as navigator and changing the sys.txt file to show
    [folder]
    app="/HDD/igo8.exe"
