Results 1 to 8 of 8
Thread: Igo Primo help
    Igo Primo help
    Hey guys I have Primo installed on my Sony Nvu-83 and I was wanting to Watch video and view photos on it. I would be grateful if anyone could help me. I know primo has Picture viewer but I don't know where to play the picture
    Thanks guys
    Re: Igo Primo help
    Primo does not have a video player.
    Re: Igo Primo help
    But it does have a Picture viewer How can use it?
    Re: Igo Primo help
    Quote Originally Posted by Acidsnake View Post
    put this in the sys.ini file
    [music]
    music="SDMMC DISK\media"
    [Picturers]
    picturers="SDMMC DISK\media"
    you will need to modify the name of your card and the location
    I just made a folder called media on the root of my SD cards
    hope this helps
    Re: Igo Primo help
    Hey Matty
    Thanks for the reply
    I tried what you said but still no luck, I have a sony GPS so no SD card only Memory stick
    Thanks for the help
    147
    Re: Igo Primo help
    Press the menu button [lower left corner], then press [+ more] (lower right button).
    It will then show you the [more menu] which include [music player] and [picture viewer] among others.
    Press on [picture viewer]. Primo will then scan your system for all pictures (jpg files) on your flash disk and/or portable media card.
    You can add [oasis] section in your sys.txt to limit/exclude/include directories you want primo to look for pictures or music files in.
    Example:
    [oasys]
    include_directories="%sdcard\Music,%sdcard\DCIM" ; primo will look only in music and DCIM folder of sdcard/memory stick for music/pictures.
    Re: Igo Primo help
    Quote Originally Posted by kamoteka View Post
    Example:
    [oasys]
    Thats the Problem I can get the Music to work as i can get it to scan for, but when I click on Picture Viewer Nothing happens and there is no option to make it search for them, All I see is a blue background with waves.
    But I will just try you Oasis method and let you know how it goes. Thanks alot for the help
    Re: Igo Primo help
    And it didn't work
    I copied that into my sys and nothing is still happening I placed my pics iin DCIM
