Results 1 to 7 of 7
Thread: Igo Primo Speed Camera Alert Sounds?
    phatashki is offline Corporal
    22
    Is their anyway to change the alert sound for the speed/traffic light camera. At the moment all I can get is just a Beep! and thats it, and looking through all the menu's I cant seem to change it.
    I have gone through the data zip folder and have found the audio folder which has a couple of the sounds that was used in IGO8 for the speed camera sounds like the continues bleeping. All labelled up as !audio1, !audio2 etc....
    I have also found an audio which is like a siren sounding called !alert6 , Is it possible to have this siren sound to alert for speed camera's.
    I have thought about editing the Sys.txt file.
    This is what i have in there at the mo under the warning section
    [warning]
    speedcam_enabled=1
    speedcam_warning=1
    speedlimit_warning_visual=1
    speedlimit_warning_voice="!radar"
    speedlimit_warning=1
    speedwarn_alt_tolerance=110
    speedcam_soundtype_8=2
    speedcam_max_lookahead="200"
    speedwarn_alt_builtup_based=1
    pedestrian_warning=0
    speedcam_visualtype=1
    speedcam_soundtype=2
    speedcam_warning=all speedcam types
    speedwarn_tolerance=110
    speedwarn_toltype=1 ; absolute or percentage
    approach_beep_distances=200
    warn_distances=100
    section_beep_distance=200
    speedcam_snap_distance=200
    speedcam_max_lookahead=400
    speedcam_maxdistance_from_road=10
    Is their something I could add or change to use the siren sound instead of the beep.
    22
    Re: Igo Primo Speed Camera Alert Sounds?
    Sorted it guys, Easier just to rename the audio files from the ones it used to the ones you want
    rgs
    rgs is offline Sergeant
    30
    40
    And how are the original names ?
    Essex UK
    209
    I believe its !Alert1 !Alert2 etc all the way through to 6
    rgs
    30
    40
    Late thanks
    Gonna search for an original package shipped with the default ones. Then just replace
    May 2014
    Hi All
    in the file data.zip which is in the root folder of the igo application
    you can open it
    search for the folder ui_android then the folder audio
    there you can find all alerts as wav file
    If you need to add new alert from outside, copy it in the audio folder (the zip file will add it to the archive)
    so you have 2 ways to change the ugly alert of the speed cam
    1. either you delete the original wav file in the audio folder and replace it with a good one - make sure to keep the same name
    2. or in the sys.txt file add the above text mentioned in phatashki thread then change the speedlimit_warning_voice file name
    regards
    Jan 2013
