Results 1 to 10 of 18
Thread: igo installation on sony nv-u93t
    Hi all,
    please excuse if I sound a bit green (I am), thinking of upgrading my sony nv-u93t to run igo just a couple of questions for those who know best.
    are there any simple instructions out there?
    will I still be able to use my blue tooth phone functions?
    am I best using igo8 or a different version?
    many thanks
  2. The Following User Says Thank You to maserati For This Useful Post:
    astraclub is offline Lance Corporal
    Dec 2010
    Re: igo installation on sony nv-u93t
    ANy development on this thread?
    I am the same model and would like to know if i can download IGO8 on this. Only thing is that my NV-U93t was purchased in IRELAND and now I am in US and would like to downloas US map on this
    thanks for the help
    Dec 2010
    Hi
    I tried to follow the procedure and when i uploaded mountain volume and reset my Sonu NV-U93T, the system came on but there is a message :--
    "Fatal Error: Initialization error: no language files were found"
    I can only press "OK" button and system will go dead.
    I tried to connect the device on my win7 laptop but guess what- laptop is not reading/connecting Sony Device now.
    so this is where i got stuck :-()
    Any help please--I am so close but still so far....
    can someone help...how can my Sony NV-U93t will be read on laptop
    rgds
    D
    Dec 2010
    Any help please?
    Can someone help me please? My unit is not recognised by any pc anymore!!!
    I had all done well initially and fownloaded as mentioned in the files above
    however the unit is erroring out with FATAL ERROR -initialization error-language not found.
    Dec 2010
    Hi
    Can someone please help me here....
    My GPS unit is not been recognised by lapto. is there any other way to connect GPS unit (add harware etc or by c command somthing) and somehow copy the old original map back onto GPS unit?
    Or is there a way to bypass GPS loaded IGO and run the GPS from the memory card first so that i can reset the language error.
    I had the direction from this site but it was not clear and i got my GPS in this shape.
    As on today, I can not start the GPS unit (language error), can not get GPS connected to laptop (win7 and winxp any of them) and thus can not reload the original map ...
    help help help
    SOS
    Jan 2011
    YES, Igo 8 and Primo is working in Sony nav-u.
    You can't use bluetooth option from device.
    I will come back soon with a diagram how to install Igo on this gps.
    Quote Originally Posted by maserati View Post
    Hi all,
    many thanks
    Jan 2011
    United States
    linkwheel service
    Hello everybody. Nice to be here!
    so dep kiem viec
    Jan 2011
    US
    car dealers michigan Sterling Heights
    Excellent learn, I simply passed this onto a colleague who was doing a little analysis on that.
    auto trader florida Coral Springs auto trader texas McAllen
  10. #9
    22merlin is offline Lance Corporal
    Re: car dealers michigan Sterling Heights
    I too have a Sony Nav U 93 - I have got Igo Primo up and running thanks to these forums - however [as with others] I can't get the unit to pick up the GPS signal.
    I believe that the correct settings are Port 5 / Baud 57600 from what I have read here, but I've not been able to find this info anywhere else to verify it.
    I have tried changing the port number - but as there are so many possible combinations of Port / Baud, proceeding on a trial and error basis seems a bit futile.
    If anyone can help with the GPS I will then post the file structure & Sys.txt for the rest of you guys.
    For those above who have said they can no longer 'see' the unit on their PC - load windows mobile device center [or equivalent], plug the unit in via USB then reset it - it should then [eventually] flash up 'system' on the unit and appear in the device center. This worked for me - hope it does for you. Good luck.
  11. #10
    I have discovered that the original GPS settings used in the Sony software are Port 3 / Baud 38400 - but this isn't picked up either.
    I installed a different version of Primo - same result.
    I installed an older version of IGO from 2009 that I ran on a different unit that was stolen - same result, even though this version has an auto detect function to find the GPS - it doesn't.
    Yet the GPS still works with the original Sony software - so I can only assume that for some reason this particular unit is not compatible with IGO ? Unless someone has a better idea.
    In the meantime I'm going to see if I can get Garmin to run on it - and will report back later. Thanks to all.
