Thread: load iGO8 instead of GUI
    eskro's Avatar
    eskro is offline Staff Sergeant
    96
    any chance one of you know if my 5" screen chinese GPS
    can launch iGO8 upon booting?
    by that i mean, when i power ON my gps,
    instead of loading the main PNA GUI,
    it would directly load iGO8 right off the bat!!
    can it?
    thanx
    kamoteka is offline Master Sergeant
    147
    Re: load iGO8 instead of GUI
    I assume that your 5" Chinese GPS runs windows-ce. In windows-ce, there are many ways to load a program at start-up. One way is to add a shortcut of your program to the \windows\StartUp folder. If you have CECMD (Total Commander) on your device, make a shortcut of igo.exe and copy it to the \windows\StartUp folder. Then soft-reset your device and igo should be loaded automatically. However, when you hard-reset, you have to copy the shortcut once again.
    eskro's Avatar
    96
    and if i dont have Total Commander, how do i create a shortcut?
    147
    Then use the built-in windows explorer. Go to the folder where you have igo.exe and highlight it (click on it). Then, click on Edit - copy. Go to the windows\StartUp folder, click Edit - paste shortcut.
    Close windows explorer and soft-reset your device.
    eskro's Avatar
    96
    oh my :P ill try that.... thx
