Thread: NEED HELP for TMC setting for mio s501
    mosheys is offline Staff Sergeant
    73
    50
    I purchased the TMC kit for the Mio S501 it works fine for mio but it doesn't work with igo8 or primo I added the following to the sys.txt
    [tmc]
    source="gns"
    port="COM,1"
    baud="14400"
    there is a file in the mio Program Files\Navman\DataManager\datamanager.ini with the following information maybe it could be helpful to see why the tmc is not working
    [Default]
    gps port open=false
    gps port=VSP1
    gps baud rate=57600
    gps default protocol is nmea=true
    gps sirfbinary protocol=false
    gps sirfbinary baud rate=57600
    gps protocol switch=false
    gps use sirf clm=false
    gps cold start=false
    gps use rx flag=false
    gps reset watchdog timeout=0
    tmc port open=true
    tmc port=COM1
    tmc baud rate=14400
    tmc duplex mode=true
    tmc gns module=false
    tmc command timeout=100
    tmc command retry=3
    one2one port open=false
    one2one port=1
    one2one baud rate=115200
    msndirect port open=false
    msndirect port=COM1
    BigMallocBound=8192
    SharedMemHeap=true
    [Process1]
    WindowName=SmartST_CE
    NAVMAN_TRAFFIC=true
    3,134
    216
    Re: NEED HELP for TMC setting for mio s501
    Did you configure the tmc setting in iGo8 and Primo. Use manual configuration and not auto detect.
    You need to add the details of your tmc settings into the sys.text for iGo8.
    73
    50
    Yes I did, this is what I added in the sys.txt
    [tmc]
    source="gns"
    port="COM,1"
    baud="14400"
    In igo8 it detects the tmc but it doesn't scan just stays by 0.00 & in primo 1.1 it doesn't come up.
    3,134
    216
    Get your TMC receiver code and GNS signal code.
    Make this entries into the tmcevenlist.
    73
    50
    Were can I find this information?
    3,134
    216
    You will get the information based on your TMC subcription with the network.
    GNS signal code - make a search on the net - find your area and note the details.
