Results 1 to 10 of 11
Thread: iGo8 POI's and MAPS
    geek99 is offline Private
    iGo8 POI's and MAPS
    I bought a 5'' chinese GPS system with 800x480 resolution and 64MB RAM that came with iGO8.3.2 installed on it. If I want to update the POI and MAPS on it, what directions do i have to follow? Can i install either one of Navteq or TeleAtlas POIs? Or does it depend on certain settings on my unit like resolution, igo version etc? What about maps? I bought it new but the US/Canada maps in my unit are marked Aug 27th 2008 which seems quite old. How do I update them? Appreciate your clarification.
    Essex UK
    209
    Re: iGo8 POI's and MAPS
    Just search the forum for the latest maps. To install is just a case of downloading your chosen map and copying it over to the the map folder in igo8
    You can have either Navteq or Teleatlas, for most people it depends which has the best coverage of your area, the same with pois, you can use either with either map.
    Alexlar is offline Private
    Canada
    I have Innovatek GPS 721. I have update iGO8 now for version 8.3.2 . All looks ok, but now I have not detail maps on my screen. Where I can find new maps for version 8.3.2 ?
    In my original SD card all maps with extension fbl from 2008 Please help me in my case
    eskro's Avatar
    eskro is offline Staff Sergeant
    96
    you need maps for North America or Europe?
    Canada
    For North America
    eskro's Avatar
    96
    iGO8 R3 NAVTEQ 2009.Q4 North America Maps
    Canada
    This is the wrong link to spam site
    eskro's Avatar
    96
    there's no spam site at all,,,
    download the DLC container....
    and open it in JDownloader
    Canada
    Ok I got it, Thank you
    password please! need it to unzip
