Thread: iGO on a --> 7" GPS E900 ??
    eskro's Avatar
    eskro is offline Staff Sergeant
    96
    Would this be a good item to use as GPS?
    •CPU: Samsung 533MHz
    •OS: Windows CE 5.0
    •Memory: 128M DDR II, 2GB NAND FLASH
    •GPS / LIVE TV/ WiFi INTERNET
    •Standard SD card slot, max up to 32 GB
    •2100 mAH battery
    •7" Screen 800x480
    •No TMC
    •No BT
    •No FM
    •~$114,72 EURO + free shipping
    Link Here!
    mugglesquop is offline Corporal
    18
    Re: iGO on a --> 7" GPS E900 ??
    how does it get a internet connection? wifi?
    The 800x480 graphic files should be ok if they need scaling up slightly
    eskro's Avatar
    96
    yes wifi internet
    Essex UK
    209
    Looks fine to me, though looking at the video they have to me it looks a little big.
    Feb 2011
    Hello.
    I have a 7" GPS E900 but my igo is not finding the gps. I installed the igo and it is working normal but when I put auto detect GPS and it looks for a port / speed is not the message is: The GPS was not found.
    Could anyone tell me which port it uses or pass me a link where I can download igo running in it?
    thechachman is offline Corporal
    Feb 2011
    22
    two options
    either download/run the utility which tells you what port/baud rate the GPS is on and then update system.txt to match that
    delete those lines from system.txt entirely and reboot/restart the app and let it hunt on its own at startup.
