Results 1 to 9 of 9
Thread: IGO8 problem in chinese GPS
    have some problem for using IGO in chinsese GPS, when you back up your user data, it say that "database back up failed! check storage card."
    also iGo cannot export a track log. When i select Settings / Manage / Track Logs / <select a track log> / Export then i get this error message: "Error writing file: <track log file name>".
    There doesn't appear to be any way to minimize iGo to go back to the main menu. I have to exit iGo and then start it up again which is annoying. All the other GPS's i've used allow iGo to be minimized, either with a separate hardware button or by short pressing the On/Off button.
    is there any setting that i can add in SYS.TXT to make all those work.
    thank you.
    18
    Re: IGO8 problem in chinese GPS
    Please write your SYS.TXT and I try to help u.
    arie3333
    Jebus is offline Lance Corporal
    Put this in your sys.txt:
    [interface]
    show_minimize=1
    after i put
    [interface]
    show_minimize=1
    how can i minimize in the IGO?
    thanks
    bazzle is offline Lieutenant
    Melb Oz
    347
    33
    Load Kikker skin. Drop the skin into igo/content/skin folder
    It has the option to: Cancel, Exit, Minimise.
    or as I have been advised
    Write this lines in the sys.txt :
    [interface]
    show_minimize=1
    show_exit=1
    When you Exit it gives the option to minimise.
    Bazzle
    3,134
    216
    Quote Originally Posted by king12 View Post
    thank you.
    Which software version did you use for your China PND
    Your device CE version
    my device is wince 6
    Feb 2011
    sorry for using this thread to ask question.. I just installed igo 8 on chinese gps which using windows ce 6 and I found a bug.. when you are trying to type your address or either entering name when saving route the backspace button on top right corner is not working..
    Anyone knows ho to fix this? Been looking for the fix for a while.. Thanks in advance
    Feb 2011
    Hi, i too have a chinese sat nav (wince 60 running iGO8 version 8.3.4.142975) I have got the minimise button. When I click on it, iGO does minimise and sat nav goes to options screen, but I can't click on anything else. I end up having to do a reset. I also tried kikker 3.2, but the same thing happens!
    I hope someone can give me some advice on how to get this working properly, as it's a pain having to exit iGO to set music to play, then re-start iGO.
    Any help would be greatly appreciated.
  1. 9th November 2011, 07:54
