Thread: IGO does not start.
    3381dre is online now Private
    IGO does not start.
    i'm trying to get IGO to work on a old myguide. I accidently used an old backup from another myguide. The device id's are not the same so IGO does not start. Whitch files must i delete to get this working. I installed it from a sd-card and left the old myguide software on the flash-disk.
    3,134
    216
    Re: IGO does not start.
    Quote Originally Posted by 3381dre View Post
    Delete the device.nng file
    Do a clean install again.
    A new device.nng will be created.
    Saved it to someplace for future use
    Thanx, wil try this.
