Thread: iGO Installation problem
    Hi, i recently was given a Navman S50 3D to work on.
    I have successfully installed MioPocket 4
    The problem i now am encountering is when i load iGO it gets to the language selection screen & won't let me go any further.
    Could someone please point me in the right direction
    Thank you in advance.
    XisiX's Avatar
    XisiX is offline Corporal
    28
    Re: iGO Installation problem
    It could be memory (RAM) related.
    Try to install older version of iGO (i.e. R0) with one map only and without any POIs, speedcams, skins etc.
    stefy_hgs is offline Corporal
    28
    41
    Do you get the buttons in the down side of the screen (OK, Test and arrows)? If not it's a resolution problem (your version of igo doesn't support the resolution of the device). Look in the branding.zip/ui_go8 and see if you find the right resolution.
