Thread: gps 7'' with resolution 480x234 igo 8.3 and igo primo
    pelos is offline Private
    igo 8.3.4 work on my gps 7'' with data resolution 480x234 and igo primo dont work with data resolution 480x234 , i have the same sys. why? please help me
  2. The Following User Says Thank You to pelos For This Useful Post:
    athlonoc is offline Sergeant
    37
    Re: gps 7'' with resolution 480x234 igo 8.3 and igo primo
    Are you 100% sure the data.zip file contained within your Primo is for 480x234. Just open up zip file and make sure the folder inside is 480x234
    Also what version of Primo are you using?
    yes the data 1.1 is for 480x234 (i show it inside the data ) and i am using iGO Primo 8.5.11.155811
    henri_p is offline Private
    I have a similar issue, is the data.zip from Primo 1.1 and 1.2 different?
