Results 1 to 8 of 8
Thread: Help sought to auto start iGo8 from an SDcard
    Darkw is offline Private
    Hi there,
    I would like iGo8 on the SD card to auto start on my Tevion pwm3501 with windows CE 6 without having to search for the exe file every time I want to start the iGo8 application, could someone give me an idea on how I go about how to edit such a start up file & what tools I would need please?
    Regards,
    DarkW
    gsm_pda's Avatar
    gsm_pda is offline Corporal
    Bucharest-ROMANIA
    23
    Re: Help sought to auto start iGo8 from an SDcard
    You just have to make a shortcut of iGO8.exe and put it in the descktop folder, reset and that is all
    scarey is offline Banned
    on your card make a folder called '' shell.ini '' and put this line in it '' \SDMMC\igo8\igo8.exe ''
    I will try...
    I have tried both the shell.ini txt file on the root of the card & a short cut on the desktop folder to no avail.
    I'm probably doing something incorrect along the way & I will continue on trying for a little longer.
    Regards,
    its possible that your card is called something different and remember to use your old/manual method once to 'educate' the start up process...
    mrgadgetuk is offline Lance Corporal
    Hi Guys,
    Thought this might come in handy for those who want to use other satnav software on their PNAs. Also might be useful to 'Darkw':
    http://www.filecrop.com/pna-unlock.html
    How do you put the line in the folder? As a txt file?
  1. 23rd October 2011, 21:24
