Results 1 to 10 of 12
Thread: Please Help! Chinese Double DIN SAT NAV CD Player
    Lightbulb Please Help! Chinese Double DIN SAT NAV CD Player
    Right, I'm a real novice when it comes to this, I had a TomTom and managed to update the firmware and Maps etc no end, but now I have this new CD Player in my car I'm left clueless:
    The Sat Nav runs Igo8, I love it and deffinetly looks better than the TomTom. Every now and then, it crashes and I have to reload it all, which isn't good when trying to follow a route! I'm after maybe a new version, think I have seen an 8.3 correct? Plus would like new maps to add on. How can I find the resolution, or the operating system of the CD player? The Igo8 runs from a SD Slot on the front of the CD player. Basically I just want to be able to change things and add things, but without knowing which version I need it's quite hard, it appears Igo8 runs on alot of devices!
    Here is a picture of my device if anyone is familiar? Sorry about the pic, it's all I could find of it!!
    Any help is appreciated, I'm really quite stuck however sure you kind people will be able to help as before! Thanks again, Tom
    Melb Oz
    352
    Re: Please Help! Chinese Double DIN SAT NAV CD Player
    Thats an WD6050 or similar. I have the WD6050 running iGO8.3 really well with tts.
    What country are you in (Oz)?
    Bazzle
    Hi Baz, thanks for the reply!! I'm in the UK!! Right so where can I get the uk Igo8.3 for this unit? So glad you replied! There is hope!! Oh what is tts?? Thanks again, Tom
    Melb Oz
    352
    All igo's are nearly the same. just local files, ie. maps, dem, poi's etc change.
    There are variations for diff base units but heres a link that should work in yours? (no content folders) so you will need to get maps etc.
    BAzzle
    Thanks downloading now!
    Also scanned you-tube, you can make these units enter into Windows Desktop! How cool, will be busy playing tommorow now!!
    Is the top link Igo 8.3 ??
    Melb Oz
    352
    From memory yes.
    More UK maps BAzzle
    Hi Bazzle,
    i remember seeing your name and posts on the golfmkv.com forums. r u the same guy?
    I have same sort of problem with my Aus WD6050 unit with constant crash etc..
    tried to download the links in this post but seems to be broken..
    would you be able to upload the files again? or send to me directly? are you aware of any newer revision or update that we can use for WD6050? (e.g. TomTom etc)
    thanks for update if you get get to see this and sorry for inconvenience.
    cheers
    Melb Oz
    352
    Same.
    I sold my wd6050 and got an MT-8001
    Cant help with the issues but if you want igo Ill try and find a full linky for Oz.
    What resolution and memory is in yours?
    Bazzle
    Quote Originally Posted by bazzle View Post
    Same.
    Bazzle
    Hey Bazzle,
    thanks, I use the older version (Gen1) with lower resolution and 2Gb SD card support..
    can you also let me know how much the MT-8001 unit cost and from where?
    thank you
    Melb Oz
    352
    Quote Originally Posted by playa78 View Post
    Hey Bazzle,
    thank you
    I might have one spare in a couple of weeks. Ordered one for a chap who now is selling his car
    Bazzle
