Thread: IGO for MIPS solution?
    Exclamation IGO for MIPS solution?
    I got a GPS device from China with MIPS solution.
    Anyone who had the engine for this system?
    device describe:
    CPU:MIPS,not ARM
    software:wince5.0
    Touch Screen:800x480
    thanks a lot
    Re: IGO for MIPS solution?
    i got the same problem
    hi guys, I have the same problem, I've searched a lot and I found something that might be good for us.
    it starts, but unfortunately after "init api" it closes. this means that the license is not good.
    so I think we're close to finish...
    I downloaded from yur link but I have the same problem, on start i receive a error message. Do you solved the problem?
    can somebody help me with igo for mips?
    zhouyan is offline Private
    Aug 2011
    Nobody can help us for MIPS ?
