Results 1 to 10 of 15
Thread: Skin for iGO My way™ for Android 800x480_motogis_V2.3
    Requirements: Android devices with 800x480, iGO My way Android
    Overview: is a mix from tangbohu,motogis,sbertaud,12carrera12 480x320 skin, made by motogis.I only add "turnrestriction" .Tanks all .And especially to motogis who is happy to share it with us here
    screenshots: ( some of them are old, so some functions have been changed..but in good way ..next time i will renew them)
    9.01.2011 news from motogis:
    History:
    - Slightly redesigned interface in navigation mode:
    * Call the menu is one click on the map;
    * Switch-over to view the map - double click on the map;
    * Redesigned displaying information about speed, arrival time, etc. (Click on the window at a speed you can open / close additional information);
    * Displayed at the bottom of the street where we're going (by clicking on this line, we will switch to indicate the name of city);
    * Right and left arrows show the number of houses, past which we currently eat;
    * Each menu button performs an action with a long click on it (for example, if you hold the menu button, there will be a way out of iGO)
    * In navigation mode, if you click on the time of arrival, we will switch to display the remaining time;
    * Can still forgot something
    - Redesigned the buttons in the simulation mode route;
    - Yet finalized, adds intermediate keys;
    - To further reduce the size of data.gro 250 KB;
    - Minor bugfix;
    - turnrestriction
    PS: Some people from Germany confirme that TMC/http it`s working.
    12.01.2011
    V2.3...motogis`s news:
    History:
    * Completely reworked the algorithm to add / delete waypoints on the map;
    * Redesigned the buttons in the search on the map;
    * Added option to view / delete points (in the menu "My trip");
    * Added function to save / load / delete a route;
    * Search button in the coordinates are now in menu "Destination";
    * Changed discrete zoom maps;
    * Size data.gro still reduced to 500 KB;
    * Heap visible / invisible bug fixes;
    All credits to motogis from Ukraine.
    Re: Skin for iGO My way™ for Android 800x480_motogis_V2.3
    very dumb question where can I download the file ?
    Sorry my bad! added link 1st post...
    New skin v2.3.1
    History:
    * Ability to move the intermediate points;
    * Fixed bug off route when leaving the viewer TMC;
    * Settings menu add the button "Backup Data and Restore Data" (thanks mariupol1963!). Backup works fine, but the Restore - not working. Please run a test, who is active S-OFF. Attention! Function "Backup Data" creates on the SD card folder "backup". If you have such a folder, it will be overwritten!
    * A little small corrections;
    * Added menu item settings TMC (please test in those countries where this lotion works);
    Known bugs:
    * Does not return the stored data;
    * Removes the stored routes if you run igo;
    Brilliant, works nice on my Samsung Galaxy S. Many thanks for this kind work.
    Hi. Can you upload the link again?
    Existing links not working.
    Cheers
    I dont think you can
    sorry wrong place
    Existing links not working!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
