Thread: iGo My Way NA v1.0 Not Working After iPhone Unlocked
    The application used to work with my jailbroken iPhone, but it stops working after I unlocked my phone to use with other service provider. It just showed the loadup screen then closed down. Any help is greatly appreciated. Thanks.
    Re: iGo My Way NA v1.0 Not Working After iPhone Unlocked
    IT does not work beacuse for unlock purposes you had to upgrade your iphone baseband (which is not) unlockable to an ipad base band (06.15.00) which kills the gps....if you have done this, you must wait till 4.3 update s out which will restore iphone baseband again...
