Results 1 to 7 of 7
Thread: PROBLEM with primo 1.2
    i've put the primo 1.2 in my htc diamond 2, after i am choosing the language i get a window "failed to open file: $traffic_speed.spr exiting application. what do i do?
    thank's
    Essex UK
    209
    Re: PROBLEM with primo 1.2
    Open your sys.txt and try deleting the line traffic_speed.spr
    patrol42 is offline Lance Corporal
    sorry i am addressing this question here... but I can'nt find an answer.... when i hit NEXT after I set uyp the map ie country uk, brighton,queens road house number, it finds it on the map correctly, so then i hit next to proceed but it says waiting for GPS signal.....and it does not moove from there on... I hit ok and it goes back to map... so I can not set it as my destination...
    I hope i am clear.... anybody can help....
    Installed on an HTC polaris.
    Essex UK
    209
    Do you never get a gps signal?
    Try setting your gps port and baud rate in the sys.txt
    Hi there Matty538, thanks for the reply.....NO I do not get a gps signal though on IGO 8.3 which I have also install I do get gps signal..
    How do I put it in the sys.....I mean what should I write...??
    Matty538............Thanks a million....I've made it, have changed port from 6 to 4 and it works GREAT.........Thanks again mate....appreciated......
    REGARDS
    Patrol42
    mosheys is offline Staff Sergeant
    73
    50
    The auto wake up when the external power is re connected primo1.2 freezes on Megellan magellan 4250 is there any fix for it?
