Thread: iGO Prim 1.2 no sound but I do have sound with iGO 8.3
    May 2011
    I have a 2din device (Mitsubishi car) which is working fine with iGO 8.3. I have now installed iGO Primo 1.2 but I do not have any sound.
    The iGO 8.3 sys.tx contains two sections for the sound. I reused the same but it is not working so I guess on iGO Primo these parameters are not used anymore and I have to use new ones. Do you have any idea, please?
    [modules]
    IEXTERNAL_BACKGROUND_PLAYBACK_MANAGER="KRS_EXT_BG_ PB_MGR"
    [interface]
    external_mp3_player_window_name="Main"
    [keybind]
    175="VOLUMEUP"
    174="VOLUMEDOWN"
    C1="TOGGLEMUTE"
    [sound]
    set_volume_force_on_mute=1
    sound_krs_standard_volume_setting=0
    sound_max_level = 10
    sound_level_0=0x00000000
    sound_level_1=0xC000C000
    sound_level_2=0xC71CC71C
    sound_level_3=0xCE38CE38
    sound_level_4=0xD554D554
    sound_level_5=0xDC70DC70
    sound_level_6=0xE38CE38C
    sound_level_7=0xEAA8EAA8
    sound_level_8=0xF1C4F1C4
    sound_level_9=0xF8E0F8E0
    sound_level_10=0xFFFFFFFF
    use_method = 1
    sound_q_length = 200
    QUEUE_LENGTH = 0
    14acres10 is offline Sergeant
    30
    98
    Lightbulb Re: iGO Prim 1.2 no sound but I do have sound with iGO 8.3
    hi
    i have iGO Primo 1.2 and i dont seem to have a lot in my system file for sound, only this
    [sound]
    csv_voice_enabled=1
    [tts]
    tts_buffer=131072
    announce_exit_directions=1
    tts_logics=3
    priority="HIGH"
    always_say_road_names=1
    announce_street_name=1
    skip_exit_numbers=0
    perhaps delete some of your system text, it might work on igo8 and not on primo 1.2?also go into system setup and into sounds and warnings and click on the voice language, mine has english (uk)kate(tts)v3.3 and click on voice! does it sound ?"have a nice trip etc"? .This will see if your voice files are set up ok
    hope this is of some help , also look up this excellent forum and im sure you will come across all you need to get up and running.
    cheeres
    May 2011
    Thanks! I did test that and I cannot hear voice. In my iGO 8.3, if I remove these lines then I got no sound. If i put it back then sound is working again. Something changed in Primo because it seems that these line do not have any effect
    [modules]
    [interface]
    May 2011
    By the way, my device is a Korean device Glosys G7 model: GLOSYS inc
