Results 1 to 10 of 19
Thread: hi all can anyone help
    crosswire is offline Corporal
    15
    got a Chinese unit off ebay the problem is i have the map on and drive around every thing is fine but when i set a destination on some roads that are ok with the map on reboot the system on the jurney what is wrong with it ????
    tonygps's Avatar
    tonygps is offline Command Sergeant Major
    201
    Re: hi all can anyone help
    really can't understand what was your problem.
    can you describe more? so that other people might have an idea on how to solve it.
    furthermore, need to know what is your model (picture might be nice..), your gps com port & baud rate, your screen resolutions..
    thanks..
    15
    i have a chinese unit for a passat i drive round with the map displayed the map stayes on but if i put a destimation in the sat nav some not all of the roads i go down make the sat nav reboot but the directions (sound) still work can anyone tell me what is wrong???
    realbob's Avatar
    realbob is offline Staff Sergeant
    74
    @crosswire
    Like stated before, please tell us what is you device model, resolution of screen and if it is Win CE5, CE6...
    Thanks.
  5. 21st May 2010, 14:23
    Banned
    hexe's Avatar
    hexe is offline Lance Corporal
    This is not a help !!!! On other boards this is a reason to bann you.
    hx
    15
    better ban me then very helpfull forum
    realbob's Avatar
    74
    @crosswire
    The ban was not about you, but about 0545 which refered a website....
    All we ask you to is provide your GPS model and screen resolution and WinCE version if possible... Then we will be able to help!
    15
    HI sorry i took that the wrong way it is running igo 8.003 screen 800x480 WinCE 5 not sure about model thanks
  10. #9
    realbob's Avatar
    74
    @ crosswire
    Start by going here:
    Download this release...: http://hotfile.com/dl/43666767/93d11...0x234.rar.html
    Pass: 123go
    Extract directly on SD card, delete all content of save folder. Add your DEM, POI and MAP files and give it a try. Be sure they are igo8 R3 content files.
    Then delete the SAVE folder.
    Change those settings in sys.txt file:
    Add a ; in front of port and baud and try a autodetect in igo8
    [gps]
    port="2"
    baud="9600"
    Then in [rawdisplay] change 480 x 234 for this:
    screen_x=800
    screen_y=480
    stretch = 1
    Then in [interface] change 480 x234 for:
    resolution_dir="800_480"
    vga=0
    Let me know.
  11. #10
    15
    HI Realbob
    this is what i have in my sys. txt.file
    [rawdisplay]
    screen_x=800
    screen_y=480
    [debug]
    skip_eula=1
    [interface]
    maxzoom2d=6000000
    show_exit=1
